Dormer Pramet
The Dormer Pramet Shark E894 tap selection.
New Tapping Option for High-End Threading
Sept. 21, 2023
The high-performance HSS-E thread-forming tap suitable for through holes and blind holes in a wide range of materials, with toughness, hardness, and heat resistance to the entire tap.
DORMER PRAMET added a new option to its offering for high-end threading: the Dormer Shark E894 is a high-performance HSS-E thread forming tap suitable for both through and blind holes in a wide range of workpiece materials. The premium materials used in the taps provide a balanced ratio of toughness, hardness, and heat resistance to the entire tap.
The Shark E894 is available in DIN/ANSI standard and UNC, UNF and metric thread forms to provide options for CNC milling operations worldwide. With a new forming lobe geometry, optimized post-treatment, TiN coating, and oil grooves providing lubrication up to 3.5xD depth, these taps are the first choice for highly demanding mass production threading applications.
Learn more at www.dormerpramet.com
