Worker operating CNC milling machine.
Advanced Machining That Drives ROI
June 21, 2023
“Return on investment” is not a simple calculation for machine shops, but using technology to optimize processes helps to achieve higher productivity, reduce costs, and maximize investment choices.
Maximizing return on investment (ROI) is critical for manufacturers seeking growth and sustainability. For any machining operation, computer numerical control (CNC) is a manufacturing technology with vast potential for performance improvements.
ROI is much more straightforward in marketing, retail, hospitality, and other industries where the results can be categorized more discretely, and linked to results. That’s not the case in niche markets. Calculating ROI and determining if you’re up or down financially can be challenging, at least on a small scale. Advanced CNC machining is an example where the so-called “payback period” may not come for years, and there’s no clear way to know when it has arrived.
Nailing down the particulars to understand CNC machining ROI is elusive because many costs are associated with manufacturing operations and running a successful business. Many costs extend beyond the initial equipment purchase: For example, machine shop operators also must consider the costs to run the machines, the materials used to create components, sourcing, supply chain concerns, the property or shop facility, and manual labor. The return on investment cannot be tied directly to the machinery alone.
How and why
How do you calculate CNC machining ROI? It’s all about the purchase cost of the machine and how long it lasts. The longer the machine’s service life, the more it will produce and the greater the potential to recover costs.
Complicated calculation. Calculating CNC machining ROI requires you to dig into the specific programming equations. There are several equations to help you discover the cost of running and buying the machines and identify resale value. Driving ROI also involves getting the most of the equipment’s service life, and there are several ways to do that:
  Increasing machine efficiency to improve output
  Keeping the machines well-maintained and operational
  Performing auxiliary tasks like cooling or cleaning
  Enhancing automation and sustainability
Other factors to follow include cycle times, tool life cycles, parts quality, and machine reliability. These factors can be addressed with advanced CNC machining techniques, too. Here’s how:
Precision and accuracy. Advancements in CNC machining have revolutionized process precision and parts accuracy. Modern CNC machines can achieve extremely tight tolerances and produce complex parts with impeccable consistency. This level of precision reduces errors and rework and enables manufacturers to deliver high-quality products that meet or exceed customer expectations.
Eliminating produce quality issues allows a business to raise its reputation, secure customer loyalty, and increase ROI. Many costs associated with defects and failures are reduced. For example, specialized automotive parts with higher durability and better resilience that meet the necessary crash ratings rely on strict quality controls on the manufacturer’s side. The boost in precision and accuracy for modern or advanced machines is invaluable.
Increased production speed. One primary advantage of CNC machining is the operator’s associated ability to optimize production speed. Advanced CNC machines have high-speed spindles, automatic tool changers, and sophisticated programming capabilities, sometimes spearheaded by machine learning and AI. These features let manufacturers achieve faster cycles, reducing overall production lead times.
Maximizing production speed helps a business to meet deadlines more efficiently, handle larger order volumes, and improve customer satisfaction. Producing more in less time directly translates to higher ROI. More parts per shift mean higher profitability.
You should choose the right CNC machines for the task, which means understanding the different types and their best use cases.
Cost reduction via automation. Automation is a key driver of improved ROI in CNC machining. Integrating advanced robotics and artificial intelligence lets modern CNC machines operate autonomously for extended periods. This reduces the need for manual intervention, minimizes labor costs and eliminates the risk of human errors.
Automated CNC machining systems can optimize material utilization, reduce waste, and improve overall process efficiency. These cost savings contribute directly to an enhanced ROI for businesses. One of the challenges of adopting modern automation is the upfront cost, which can create more financial limitations, but running an operation without workers reduces labor costs.
Flexibility and versatility. CNC machining techniques have become increasingly versatile, allowing manufacturers to tackle various production requirements. Moreover, multi-axis machining capabilities enable complex geometries and intricate designs to be easily achieved.
This versatility enables businesses to diversify their product offerings, adapt to changing market demands and explore new revenue streams. Expanding capabilities lets manufacturers unlock new opportunities and drive ROI growth.
Enhanced process optimization. Advancements in CNC machining also have led to improved process optimization. Simulation software and virtual modeling tools allow manufacturers to optimize tool paths, predict potential issues and simulate manufacturing processes before production begins.
Virtual prototyping capabilities minimize trial and error, reduce set-up times, and maximize machine utilization. More data helps these solutions become smarter, leading to additional realized improvements. Optimizing processes with technology lets manufacturers achieve higher productivity, reduced costs and improved ROI.
Stay up-to-date
The precision, speed and automation capabilities of modern CNC machines let manufacturers produce high-quality products at reduced costs. On top of that, the machinery’s flexibility and versatility enable businesses to adapt to market demands and expand their product portfolios. Enhanced process optimization through simulation and virtual modeling minimizes errors and maximizes productivity.
Manufacturers should embrace these advancements and invest in the latest technologies to streamline operations, reduce costs, deliver superior products and gain a competitive edge in the market. They can reach that payback period faster by producing more pieces in a shorter time frame with fewer complications.
Latest from Shop Operations
Stephan Pietzko | Dreamstime
BiancoBlue | Dreamstime
Divinesky27 | Dreamstime
